Hi guys,
Hate to see this go but I've sold the car it was running on.
For sale is a STACK ST8952 Standalone Data logger.
This Data logger has 8 inputs and monitors and records up to 20 channels at up to 50Hz a channel. This is a standalone system that doesn't have visual display but I can be added if you wish.
Included in the sale:
STACK ST8952 Module + Loom
Starter Network Harness
Wheel speed sensor ST670 cost $200
Solid State Oil Pressure Sensor ST747 cost $130
G Sensor ST791 Cost $530
Lap timer receiver ST543 Cost $320 Needed to generate the track maps in the analysis software
DATAPRO V6 Softare (The latest and greatest fully upgraded software enables you to use generic sensors instead of the expensive STACK ones. Pressure and temp sensors can be had from $20 and any sensor that outputs volts or ohms can be integrated using the custom sensor manager shown in the pictures below)
The performance upgrade pin has been activated at a cost of $450 giving the predicative lap time function.
The only thing you will need is a STACK ST8990 or ST8991 Download cable as I lost the one that came with the unit. I have seen these come up on ebay or racecarsdirect.com every so often for $50-100 used, buy it new or make one your self if your clever.
In light of this I'm asking only $600 for the unit, which is pretty cheap for a data logger with the most expensive sensors included.
Please contact me on 0499988821 as this will be posted to multiple sites
https://www.sau.com.au/forums/topic/444943-fs-stack-data-logger/
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
