Having a shed clean out.
Note I am moving house and I don't want to take any of this with me so offers are more than welcome.
I have 3" cat out of my GTSt good condition$80.00
There is a condenser in good condition $50.00
Heater box, blower fan and evaporator $20.00 each
Std sway bars for R33 GTSt $10.00 each
And finally there is an assortment of interior panels. Let me know what you want an I will look for it. They are $5.00 each
I would like to keep these as pick up only but let me know and I may be able to help with postage quotes.
They are located in the Hunter Valley NSW.
https://www.sau.com.au/forums/topic/454151-various-r33-stuffs/
  • 3 weeks later...
