Apexi S15 PowerFC DJetro. This is the MAP version of the PowerFC. Comes with EL Controller, looms and ALL sensors in as new condition. $1000 ono.
http://www.nengun.com/apexi/power-fc-d-jetro-free-t-shirt-offer
Autronic SM4 Ecu. Motorsport grade ECU used on everything and anything. Comes with all looms and sensors. $1100 ono SOLD
http://www.mrm-racing.se/index.php?pageid=SM4e
Apexi ACV-R Boost Controller. Comes with all looms and sensors. $250 ono.
http://www.nengun.com/apexi/avc-r
Blitz ID3 Boost Controller. Probably the best EBC you can buy. Comes with all looms and sensors. $300 ono. SOLD
http://www.blitzpowerusa.com/techsupport/pdf/sbc_i-d_iii.pdf
Tien Flex Coilovers. Excellent condition with Apexi springs on the fronts. Comes with EDFC synchros and controller one connection just needs soldering. $1000 ono.
Nissan S15 GT Leather Seats. Excellent condition. $500 ono SOLD
Old model Velo GP-90XL in Red. Excellent Condition $400 ono.
S15 Nismo Cluster with ~17,000 km Excellent condition $500 ono. SOLD
S15 SR20 incl. intake manifold, fuel rail, Midnight Mods baffled sump, Tomei Ras and Powerbond underdrive pulley (excluding. hot side, coil packs, injectors, rocker cover) Engine has done approx 33,000 km's and two track days. Price includes installation of new Nissan valve springs, compression test and leakdown test before sale by Sabbadin Automotive. $4000 ono.
S15 ARK Design Apexi copy radiator. $250 ono.
Apexi GT Delta-Fin intercooler core, genuine and rare as hens teeth. $1300 ono.
S15 6 speed gearbox approx. 33,000 km's. $600 ono. SOLD
ORC409 6 speed clutch and ORC lightened flywheel. Works great bitey as. $700ono
Evo Brembo full front brake setup for Silvias incl. rebuilt evo calipers, touge factory adapter brackets from the US, HEL braided lines, 10 lap-old PMU SCR rotors and HC800 pads. $1800 ono.
Nissan BM57 BMC, hard to find and professionally rebuilt. $400 ono.
SPL S15/S14 Castor Rods BRAND NEW IN BOX - I can't find a price other than Garage7 at $380 which I think is too dear so if you want them find out what they'd cost locally and we can work it out. http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=2960&category_id=617&option=com_virtuemart&Itemid=53
Cusco S15/S14 Camber arms, excellent condition $320 ono.
S15 replica Vertex Rear bar, skirts and replica DMax front bar in red $250 ono each.
I'm flexible on price - make me an offer. Located in Melbourne VIC.
For trades looking for mint S14 5-speed gearbox that's in the car and able to be tested, R33 front calipers and R33 non-abs BM50 BMC.
Alex
0447738908
Post updated.
Apexi S15 PowerFC DJetro. This is the MAP version of the PowerFC. Comes with EL Controller, looms and ALL sensors in as new condition. $1000 ono. SOLD
Apexi ACV-R Boost Controller. Comes with all looms and sensors. $250 ono. SOLD
Nissan BM57 BMC, hard to find and professionally rebuilt. $400 ono. SOLD
Alex
0447738908
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
