Having a problem with my RB20 swapped project hatch. I bought the car with the motor in it and it sat for a while before I got to it. Completely stock RB20 aside from a FMIC. Wiring specialties harness. Walbro 255.
The car refuses to start after it sits for a few days unless you give it some ether. It'll fire right up on ether and idle pretty well but it has absolutely no power. It barely makes it around the perfectly level parking lot at my shop and doesn't want to build any boost. The car will continue to start (without ether) but stops starting once it sits for a day or two. Symptoms are exactly the same with the MAF unplugged.
What I've done so far:
New plugs - good spark across all 6 coils
New MAF
New known good ECU
Boost/vacuum leak tested - all good
New fuel pump
No codes at the ECU
Fuel pressure is solid
Timing is good, pulled the front covers and everything is lined up at TDC.
Fresh gas
Compression tested - ~160 PSI across all 6
Fresh CAS
What's tripping me up is that it exhibits identical symptoms with the MAF plugged and unplugged. Am I correct in thinking that if this was some kind of sensor/ECU problem the car would at least be drivable in limp mode? It's not at all. Starting to think this is a fuel problem? I'm going to send my injectors out this week so that should hopefully eliminate that variable.
Can anyone shed some light on this? I have an FSM but it hasn't been much help so far.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
