Only EOI at this point, i do want to sell but i am unsure.
Located: ACT
Price: Cash Offer or Swaps
Details:
R32 GTST
RB25DET
Imported In 1999
(Private Import Gold Plate)
Refurbished Turbo (Stock)
New Gaskets (Manifold to Block, Turbo to Manifold, Dump Pipe, Catx2 and Exhaust)
New Nuts (Turbo Manifold)
New External Fuel Pump (Raceworks 250Lph)
New Fuel Pump Fittings
1.5 Litre Surge Tank
New Front Discs And Pads (T2 Street Discs, Winmax Pads)
New Front Adjustable Lower Control Arms & Castor Rods (Hardrace)
New Front Upper Camber Arms
Oil Cooler w/sandwich plate
Brand New Silicone Joiners (Raceworks)
Brand New Vacuum & Boost Lines (Raceworks)
Front Mount Intercooler
GTR Genuine Grill
GTR Genuine Bonnet (Bit Of Damage)
Apexi N1 Coilovers (Set)
HID Hi & Lo Kit
GFB Boost Tee
Aftermarket Weather Shields (Pair)
Modified Headlights
Battery Relocated To Boot
Brand New Radiator w/Twin Thermos (Wired To Switch In Cabin)
Serviced 400kms Ago (Penrite 15w 30 Full Synthetic)
Boss Kit & OMP Wheel
3x Brand New Autometer Gauges (Water Temp, Oil Pressure & Boost)
Pair Bride Racing Seats
GTR Foot Rest
Recently Redone Headlining (Dyed Black and Reinstalled)
Red Cluster LEDs
White LEDs Everywhere Else
Electric Mirrors (Still All Function)
Electric Windows (Drivers Switch Won't Undo Passenger Side)
Central Locking & Alarm Installed
Sony Headunit (Aux, CD)
2x Fusion 6x9 In Rear Pastrol Shelf
2x Alpine Type R 6" in front
Rockford Fosgate P1 12" Sub with Rockford Fosgate Mono-Block Amp
https://www.sau.com.au/forums/topic/463874-r32-rb25det/
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
