WTB: Skyline R32 GTS-4 Coupe
Hi all,
I must say firstly I am new to this whole forum thing so please bare with me.
I am looking to buy an R32 GTS-4 Coupe. looking for something clean and not heavily modified.
I owned one about 10 years ago and had to forcibly sell her due to some work commitments at the time and regretted it ever since. Have longed for the time to own one again and just a spew how hard the are to find in good condition and not molested.
Please let me know as I am ready to buy.
PS. I have a 1991 E30 BMW 318is that is in excellent original (except wheels) condition that I may part with if someone was keen for that type of deal.
Cheers.
https://www.sau.com.au/forums/topic/471711-wtb-skyline-r32-gts-4-coupe/
  • 5 weeks later...
  • 3 weeks later...
