Leather in Sky, wat colour?
Hey guys!
I have a Silver 95 Silver Sky and im getting the interiour done in leather.
Just wondering if anyone could suggest a descent colour? or colour scheme??
any pictures would also be appreciated.
its costing me $800.00 for front seats, back seats door pods and handbrake and gear boot.
If anyone else is intrested contact me and im sure i can get us a group discount.
Ill wait til mine is finish b4 ill reconmend anything but.
Donnie
[email protected]
https://www.sau.com.au/forums/topic/4892-leather-in-sky-wat-colour/
Hmmmm, I just bought a batch of leather for $115 per meter, this stuff is pretty good, but after looking at the cheaper stuff there's no way I would use anything less.
Make sure you see what grade they are going to put in your car.
But let me know how you go, I've got a silver 1995 R33 as well :D:P
Whoops whoops,
its imatation leather,
i spoke to him 2day,
still cheap for the whole car i reckon.
He said leather will cost me X 3 , so $2400.00
But yeh he sat me down and talked to me about the advantages/disadvantages of having leather/imatation leather.
"leather is like your skin, you gotta look after it" ?
Fook dat S(-)it, i just wanna wipe it down :0
heheheheh
will keep you posted with pix's when its complete, his doing the rears first.
I went with a gold tan, eekkk, looks so bright :D but i like it.
I woudn't mind a whitish cream but i would mess it up too easy :)
Donnie
My car is gonna be done in imatation leather,
hopefully ill have it finish for the cruise on 27th of October.
Ill show you guys :D
Actually if anyone is intrested i can see if i can get a group discount for yas??
If anyone is intrested
PM me
or email me [email protected]
ill tok to him and see what he'll charge,
his in Mt Druitt,
If anyone wanna meet up with me to go see him thats fine too..
I gotta go to pick up my rear seats.
Donnie
Originally posted by R33
If only it actually was an R33 GTR
:uh-huh:
yeap it is actually GTR with Sunroof!
as far as I know they are not factory option but he put it in GTR
actually it's way far from stock GTR, it all re bulid with HKS parts... almost everyting is rebulilt. with after market parts...
and the guy who owns is very thin... when I watched video from high octane, he just look like JAP racer! heheheh
anyway that's one nice GTR!!!
cheers
Joe
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
