Just want to see if there is any interest towards a GROUP-BUY for the R33 Stealth Wing (flat spoiler).
They sell for like $395 (supplied only)(on top you need to pay for delivery) and I inquired and if I get 5 or more I can get it for $325 deliveried to your door.
If interested, please post here. But only if you are 100%
Thanks
https://www.sau.com.au/forums/topic/49103-r33-stealthrearwing/
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
