I offer $150...  I can pick it up...
Hmm your twisting my arm, how does $175 sound. .pickup shouldnt be a problem. If no one wants it for $175 by the end of the day then its yours for $150. Im northisde Brisbane.
mic
mic
Sounds good... Send me a PM at the end of the day if your still keen... I'd offer more but I can get the bolt on one from Japan for around $175...
You sir, should recieve a warning for that...  :wassup:
Go and clean the house you stay at home Dad....
lucky you're not a mod anymore then huh ;)
Not MR. Mum yet, but not long to go now :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
