Ok my 32 landed last week, and i even spent the extra money to get it shipped in a Container. however i know those theiving CUSTOMS bastards took my HKS Boost Controller unit so i need another one.
I am looking only for the Cabin module, as they nicely left the sender unit in the engine bay.
Can anyone help?
BTW I know it was customs because i personally know and have met the guy in japan who packed and sealed the container in Japan, and only Customs could break the seal and open the container for inspection in Aust.
Cheers
Ross
https://www.sau.com.au/forums/topic/50332-hks-ebc-3-or-4/
I think you might be out of luck. My EVC instruction clearly mentioned that both the sender and in-cabin unit must be of the same serial # to work. But that's my HKS EVC EZ-II, not sure for your EVC3 or 4 but I reckon might be the same case. You'll have to get the whole complete set to replace it. Best of luck finding one mate.
https://www.sau.com.au/forums/topic/50332-hks-ebc-3-or-4/#findComment-1000491
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
