Brand New Boomerang A2002 Alarm, opened box.
Just bought it but is not what i want for my alarm system so is up for sale.
All optional accessories included.
First offer over $550 get it...
[email protected] or 0418 388 125. from melbourne City
It is the same as this one
http://www.skylinesaustralia.com/forums/sh...ead.php?t=51845
Details:
The Boomerang A2002 has been around for a couple of years now and is one of the best alarms on the market. Please don't compare this alarm to cheaper imitations. The Boomerang is a class A car alarm with advanced features.
The package comes with all the optional accessories and includes the following;
Usual Items Included
Main Control Module
Remote Control (two way)
Communication Module
Wiring Harness
Battery
User Manual & Labels (stickers)
Additional Items Included
One Way Remote
Shock Sensor (Dual Stage)
Siren (110db)
External Relay
Carrying Case for Two Way Remote
Standard Features
Arming & Disarming
Door open sensing
Shock sensing
Start disable in arming status (Immobilizer)
Auto-rearming Passive arming
Hidden Alarm
Vibration of the Remote Control when the system is triggered
Beep sound & icon flash on the LCD screen when the system is triggered
LCD screen illumination when the system is triggered
Emergency panic alarm
Convenience Features
Automatic door/unlock
Indoor temperature monitoring on the LCD screen
Ignition auto door lock/unlock
Driver Paging
Car finding
Trunk Release
Personal system set-up on the Remote Control
Remote Control's LCD screen illumination
Temporary lock of the Remote Control's button
System override valet
Automatic diagnostics of the system's status
Operation error report
Battery low warning
Programmable personal alarm clock
Passive door lock
Automatic illumination of the dome light when disarming
Five selectable different personal alarm sound tone
Engine Start Features
Remote engine start
Programmable engine start
Cold weather start Turbo timer function
https://www.sau.com.au/forums/topic/52120-boomerang-a2002-remote-start-alarm/
  • 1 year later...
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
