I got a mate to install my stereo into my new r31, its all fine except the volume increases and decreases by itself. He used factory wiring except for the power lead which he ran from the lighter power source, he has done this with other installations and said it works fine. I had this unit in my previous r31 and it worked fine, so i don't know what is wrong this time. If anyone could help me out with what they think the problem is, or how to rewire it correctly, it help a lot as i dont want to spend a great deal of money on a unit which just annoys me.
cheers
mine was sorta the same...except one day it got louder and has stayed that way...i used to cruise with it at vol10, now i cruise with it at vol4 or vol6!! no settings have changed...
what h/u u got? are they amped? what speakers? is it all of them only the fronts? sub?
i got a pioneer unit, it is only a few months old and was $1000, so it shouldn't have nething wrong with it. i have pioneer 240w 6 X 9's in the rear and pioneer 240w 6's in the front, none of which r amped. i did have a pioneer 12" sub but i blew that about 6 months ago. Thats basically it, ne help willbe good
well my h/u is also pioneer. my mates have the same one (dehp3550mp) but theres cuts out on the left hand side when they turn a left corner n stuff...check all your wires again, ring up the place where u got it installed (if u didnt do it yourself) and say somethings wrong is it still under warranty...
His mate installed the head unit so i take it theres no warranty on the installation hehe,
ummm if the volume goes up and down on its own i really think it wont be the wiring, Check the wiring again make sure its all ok.
One test you can do but its a pain in the arse, this will tell you exactly where the problem lies. Fit it to another car or take it to a car audio place(strathfield car radios) and ask them to test it on there test bench(will only take 2 minutes to test), if the volume still goes spastic then send the unit back to pioneer to fix if not, then its something with the installation
-B
ps: just because the unit says its pioneer and its only few months old and costs over 1000$ doesnt mean it cant break down. I've used alpine h/u in my car and it hasnt failed since. Make sure you still have the paper work when u bought the unit and do what i said above
i got a Pioneer DEH6550 and theres an automatic volume adjustment which u can turn off. the volume increases when you drive faster due to "higher engine and road noise". i think its the ASL or something similar to that.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
