ooo mine is CA31-703434 6/89. It was RB20DET Auto though, but converted to 5sp later on.
Yours is also July 89, not June 89.
FAST Information for CA31-703746
Model Series: A31
Prod.M/Y: 8907
Colour: KHO
Motor: RB20DE
Drive: 2WD - FR
HICAS: Yes (as you can tell by the "C" infront of you VIN number)
I tried comparing your cars details to mine, and I cant quite tell which box is for transmission type. But thats really irrelevant now anyways. Yours could very well have been factory 5sp.
JK
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1063853
Model Series: A31
Prod.M/Y: 8907
Colour: KHO
Motor: RB20DE
Drive: 2WD - FR
JK
thanks for that .....anyone want to buy some fender mirrors :(
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1064243
those mirrors are really uggers aren't they?  grandpa stylinz :spew:
what are your plans for it?
ahh those mirror`s are perfect...if u want the jap taxi look
cars are being sourced for the Aspley drift gang down the road from me...this one will proberbly end up metalic pink..with all the gear...don`t think they`ll use mirrors somehow
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065177
the white one will be a DE auto hicas it looks exactly like mine same wheels same front skirt and everything so i can pick that one
the grey one could actually be a RB20 E, not sure but im pretty convinced on the white one
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065593
white is manual
silver is 6/88 rb20e
thanx
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065641
Body trim doesnt mean shit. Its a nissan. they change their mind on anything at any time.
Errr dude I just said exactly what it was...theres no convincing needed :)
JK
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065697
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
