ooo mine is CA31-703434 6/89. It was RB20DET Auto though, but converted to 5sp later on.
Yours is also July 89, not June 89.
FAST Information for CA31-703746
Model Series: A31
Prod.M/Y: 8907
Colour: KHO
Motor: RB20DE
Drive: 2WD - FR
HICAS: Yes (as you can tell by the "C" infront of you VIN number)
I tried comparing your cars details to mine, and I cant quite tell which box is for transmission type. But thats really irrelevant now anyways. Yours could very well have been factory 5sp.
JK
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1063853
Model Series: A31
Prod.M/Y: 8907
Colour: KHO
Motor: RB20DE
Drive: 2WD - FR
JK
thanks for that .....anyone want to buy some fender mirrors :(
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1064243
those mirrors are really uggers aren't they?  grandpa stylinz :spew:
what are your plans for it?
ahh those mirror`s are perfect...if u want the jap taxi look
cars are being sourced for the Aspley drift gang down the road from me...this one will proberbly end up metalic pink..with all the gear...don`t think they`ll use mirrors somehow
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065177
the white one will be a DE auto hicas it looks exactly like mine same wheels same front skirt and everything so i can pick that one
the grey one could actually be a RB20 E, not sure but im pretty convinced on the white one
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065593
white is manual
silver is 6/88 rb20e
thanx
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065641
Body trim doesnt mean shit. Its a nissan. they change their mind on anything at any time.
Errr dude I just said exactly what it was...theres no convincing needed :)
JK
https://www.sau.com.au/forums/topic/54272-fast-software/#findComment-1065697
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
