  • Replies 44
omg AURON!!!! hes a legend, i cant believe it was a stupid dream, not that i liked Titus much anyways, cloud rips all main charas in ff games! (that guy in FF9, wtf was that shit)
I thought he was already dead? LOL i cant remember, he was awesome! But part 10 wasnt that good, it started to go downhill with 9. Final Fantasy 12 will be the best Final Fantasy EVER!! any1 seen the clips? OMG!!! :wassup: Balflear Looks so cool!
But i would have to say my favourite would have to be Vincent Valentine from Final Fantasy 7.
Any1 played Final Fantasy 6(jap) 3(US) ? I highly recommend it if ur not fussed about the graphics!
Might fire it up on me PS1 actually..........
More Final fantasy info for the older games:
http://www.ffonline.com/
https://www.sau.com.au/forums/topic/55613-rpgs-any1/page/3/#findComment-1227028
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
