I'm starting to mod my R32 and thought I'd start with the exhaust.
Prefer noise legal, stainless, cat or turbo back.
I'm also looking for an intercooler and upgrade turbo plus all other necessary upgrades.
Let me know what you've got to offer.
https://www.sau.com.au/forums/topic/55718-r32-3-exhaust-and-other-mods/
I have a full 3 inch exhaust with a custom split dump pipe, Carsound cat, and Fujitsubo Giken muffler. Its extremely quiet. never been pulled over for it, flows very well, and doesn't attract attention. the piping is mild steel.
Its for an r32.
I'm after $750 for it negotiable.
