Guest BIGBADBK
I've run the diagnostic check on my climate controll and it comes up with an error in the PBR. What is this. Does any one have a copy of the manual for the r32. the diagnostic check came from "The sky is the limit". My heater always seems to be on as hot air comes up through the front window vent anr the air con runs hot but the coolant temp is about 1 degre. Please help
https://www.sau.com.au/forums/topic/5589-pbr-fualt/
  • 1 year later...
pbr relates to one of the motor actuators i think.
there is one behind the glove box (small black box) and
two under the drivers foot well by the clutch pedal.
iput the air con into diag mode and then flap mode and
watched to see if these motors worked ,found the one
by the clutch pedal not moving.took it apart put it back
together and it seems to have cured the fault .i now get
hot and cold again.
hope this helps...
https://www.sau.com.au/forums/topic/5589-pbr-fualt/#findComment-627211
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
