]']how much u willing to pay for 1
got a universal 1 here..
wats the difference between universal and the standard ones??? also are they able to be put straight onto a skyline. i have 2 position where i might be bale to mount it in the stock position or on the intercooler piping..i would rather be bale to put it on the intercooler piping if possible.....give us a price range u guys will be sellin it for , i'm gettin one just a matter from who...cheers :cheers:
https://www.sau.com.au/forums/topic/56686-hks-ssqv-ne-one/#findComment-1098995
