Not sure which section this goes into but this looked closest.
I am just wondering with the SAFC i know it allows you to alter the air/fuel mixtures to help counter the stock ECU's will to richen everything up when you mod your car.
however does the SAFC or SAFC II actually tell you if it is leaning out or running rich eg provide some warning or does it just allow you to modify the mixtures.
reason for this question is i have a autometer air/fuel gauge that will show me if it is running rich or not and am wondering if its even required if i get a SAFC or SAFC II
i hope that makes sence if not let me know :D
https://www.sau.com.au/forums/topic/65164-safc-advise/
hey strutto appreciate the responce yea i wouldnt be tuning it on the standard 02 sensor it would be on a dyno with a proper tuner doing it i was more so just wondering if it is worth keeping it even if its just to keep an eye on the air/fuel levels. But if you are saying it will not be that accurate i guess their is probably no point having then.
once again cheers for the reply.
https://www.sau.com.au/forums/topic/65164-safc-advise/#findComment-1219106
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
