FIRST PREORDER
SAMPLES OF WORK CR RIMS
PRE-ORDER YOUR WORK RIMS FROM OFFICIAL AUSTRALIAN WORK DEALER.
GUARANTEED MADE IN JAPAN!
Closing date to pre-order : 28 mAY 05
To arrive : abt 1 - 1.5mths after pre-order has closed
Deposit needed: $400.00
Delivery (optional): $80.00 anywhere within Australia. If you think you can get cheaper delivery, please feel free to arrange your own delivery. I choose the courier company not based on the cheapest but the one that is reliable and will get ur rims to your door. As the saying goes "If you pay peanuts, you get monkeys!"
Color Available: Bronze, Gunmetal and White.
Prices as follows (inc.of GST and Tax) (each rims excluding tyres)
15 x 5.5JJ - $350.00
15 x 7.0JJ - $375.00
16 x 7.0JJ - $412.50
17 x 7.0JJ - $450.00
17 x 8.0JJ - $475.00
17 x 9.0JJ - $487.50
18 x 7.5JJ - $512.50
18 x 8.5JJ - $537.50
18 x 9.5JJ - $562.50
Price is per each wheel
Prices of rims in a set of 4 of similar sizes
15 x 5.5JJ - $1399
15 x 7.0JJ - $1499
16 x 7.0JJ - $1650
17 x 7.0JJ - $1799
17 x 8.0JJ - $1899
17 x 9.0JJ - $1950
18 x 7.5JJ - $2050
18 x 8.5JJ - $2150
18 x 9.5JJ - $2250
SOME OF THE COMMON QUESTIONS ASKED
Do you have any-more stock than this?
Ans: No, this is all i have
Can i order them?
Ans: yes you can, the pre-order is open for this purpose
I can get them cheaper somewhere else? Can you match it?
Ans: All works wheels are covered with warranty and it is the genuine Japan made wheels, i have seens copies of works wheel with exact packing and everything while in Thailand and Indonesia.
As an official dealer you can be assured that you are buying genuine product. All my item is inclusive of TAX and GST, and as you can from reputation, i deliver as promised.
What are the weight of the rims?
A ROUGH GUIDE ON THE WEIGHT
Size Offset Bolt Pattern Weight*
15x7.0 44 4-100 15 lbs (6.8kg)
16x7.0 44 4-100 17 lbs (7.7kg)
17x7.0 42, 47 4-100; 5-100; 5-114.3 19 lbs (8.6kg)
17x8.0 47 5-100; 5-114.3 20 lbs (9kg)
18x7.5 42 4-100; 5-100; 5-114.3 22 lbs (10kg)
18x8.5 30, 37 5-114.3 23 lbs (10.4kg)
18X9.5 30, 38 5-114.3 25 lbs (11.3kg)
____________________________________________________________________
*** IN STOCK AT THE MOMENT ***
To suit SKYLINE GTST - $2199
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +30 18x8.5
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +38 18x9.5
To suit S14, S15, SKYLINE GTST - $2199
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +37 18x8.5
To suit all SKYLINE GTR32, GTR33, GTR34 - $2250
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +20 18x9.5
To suit Accord Euro, S2000 or similar car
Work Wheels Emotion CR Kai Gunmetal 5X114.3 ET +42 18x7.5 - SOLD
To suit any 4x100 car
Work Wheels Emotion CR Kai Bronze 4x100 ET +42 17x7.0 - $1799
*** WORK MEISTER ***
Work Meister S1-2P
17 x 7.0JJ - $837.50
17 x 8.0JJ - $862.50
17 x 9.0JJ - $887.50
17 x 10.0JJ - $912.50
18 x 7.5JJ - $975.00
18 x 8.0JJ - $987.50
18 x 8.5JJ - $1,000.00
18 x 9.0JJ - $1,012.50
18 x 9.5JJ - $1,025.00
18 x 10.0JJ - $1,037.50
19 x 8.0JJ - $1,125.00
19 x 8.5JJ - $1,137.50
19 x 9.0JJ - $1,150.00
19 x 9.5JJ - $1,162.50
19 x 10.0JJ - $1,175.00
20 x 8.5JJ - $1,262.50
20 x 9.5JJ - $1,287.50
20 x 10.5JJ - $1,312.50
17 x 7.0JJ - $3350
17 x 8.0JJ - $3450
17 x 9.0JJ - $3550
17 x 10.0JJ - $3650
18 x 7.5JJ - $3900
18 x 8.0JJ - $3950
18 x 8.5JJ - $4000
18 x 9.0JJ - $4050
18 x 9.5JJ - $4100
18 x 10.0JJ - $4150
19 x 8.0JJ - $4500
19 x 8.5JJ - $4550
19 x 9.0JJ - $4600
19 x 9.5JJ - $4650
19 x 10.0JJ - $4700
20 x 8.5JJ - $5050
20 x 9.5JJ - $5150
20 x 10.5JJ - $5250
The price is for the following color: Black, white, Bronze and Silver dish with white spokes.
__________________________________________________ __________________
Work Wheels Emotion CR Kai Gunmetal 5X114.3 ET +42 18x7.5 - $2050
9 days to go before closing!
You wont go wrong with this one! Brand new genuine made in Japan rims, no taiwan made or china made rims!
Get it from genuine Work Australia dealers!
those who has ordered. thank you. keep the order coming! 7 days to go before ordering close!
guaranteed original made in japan. not taiwan or china made or copies!
get it from official work australia dealer! :)
damm the Work Meister S1-2P look really nice...!!
Too bad I dont have money to buy it!
Think you will have another one of these near say Xmas time?
i will be away on xmas period. last shipment should be in nov.
:P
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
