This is a brand new HKS EZ Guard Timer 30th ANNIVERSARY MODEL champage gold in color. I have never seen it in any car or shop for sale in Australia,only 5000 produced worldwide and only for sale in Japan.
Detail:
Security Light function:
Flashing as security light while you parked your car
Injectors detect function:
Background light changes from red to green by fuel injection, if the RPM is high, the light will change to red. The rpm is low, the light will change to green
Turbo Timer function:
Four mode of turbo timer function
Manual mode (0-10mins)
Tow memory mode (1mins or 3mins by one touch)
Auto mode (0-5mins auto setup)
Battery voltage function:
Display voltage of battery and warning signal displays when the voltage is lower than 10.0V or higher than 16.0V.
Time attack function:
3 memories, can calculate the lab time.
Three background color:
Green, Orange, Red.
more detail, if you can read japanese:
Hyperlink
I am asking $190 for this unique item and willing to post interstate by COD on buyer cost, but melbourne buyer is preferable.
  • 1 month later...
  • 3 weeks later...
  • 2 years later...
interested...saw some pics of a unit for sale on ebay (auction is long over) but trying to figure out what the small green and yellow wires are for? I know black is ground, grey is ebrake, brown is tach, big cluster of 3 wires (blue, red, green) are ign acc, etc....but ya whats the small yellow and green wires for?
im assuming one is for speedo? But that wire should be blue i would think and there is no blue
just want to know what im getting myself into if i buy this off of you...thanks
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
