i have an r31 aus spec manual
all forward gears and reverse work fine
but when in reverse having the gear being engaged and the clutch it makes sort of a grinding noise not to harsh but its there you can just hear it better when rolling back with clutch in and reverse engaged
wtf is this, gears go in smooth as
also slave cylinder question for my gearbox, the boot has come off and its become a bit rough sometimes when pushing the clutch in down the bottom, i got someone to press clutch in and out, hoped under the car found the slave cylinder boot is ****ed cylinder part is squeking, then doused thw whole thing with wd40, didnt seem to do much initally but then became smooth again
now when im stationary the clutch goes in fine but even in neurtal or in any gear, well easyer to test in neutral, rev the car a little bit and hold it then pull the clutch out and in (you can se why its better in neurtal) and if becomes rough with revs again but smooth when not reving the engine like you can feel the revs through the clutch, feels like its the slave cylinder again but havnt got 2 people and checked it out
wtf is wrong here
https://www.sau.com.au/forums/topic/73980-slave-cylinder-and-gearbox-question/
The reverse noise you describe, if I understand you properly, I think is quite normal. Try it in someone else's car [any sort] and see if you get similar feel and sound. Second symptom appears maybe to be clutch thrust bearing, but may not be a disaster. Not a good idea to rev engine with clutch pedal down. Thrust bearings are not 'high-speed' bearings, being primarilly designed to operate at around idle revs. When clutch pedal down, thrust bearing does engine revs.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
