New Stock Of Profec B Spec Ii And Turbo Timer (lots Of Function) Best Price! W/pics!!
NEW STOCK!!
BUY FROM A REPUTABLE TRADER IN THIS FORUM. YOU WONT BE DISAPPOINTED!!
CLICK HERE AND JUDGE FOR YOURSELF!!?
ALL PURCHASES COME WITH TAX INVOICE AND NO MORE TO PAY!
ABN 77 934 867 271
I accept:
- Direct Deposit
- Money Order
- Paypal (3.5% surcharge)
BRAND NEW TRUST PROFEC B SPEC II + ENGLISH INSTRUCTION* = SOLD OUT
BRAND NEW TRUST FULL AUTO TIMER + ENGLISH INSTRUCTION* = SOLD OUT
* English Instruction manual will save you a lot of frustration. Trust me on this.
-Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI).
-There are optional warning and boost limiter functions that can be programmed to offer much more control.
-The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
-This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
TRUST AUTO TIMER
It is compact in size measuring 8cm x 8cm and 2cm in height.
Comes in new casing model with internal flashing LED pattern.
It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
Able to automatically calculate and suggest the cool down time.
Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
GALLERY
GREDDY AUTO TIMER
GREDDY PROFEC B SPEC II
  • Replies 57
hey man, does the turbo timer come with a plug made up so that it can just be plugged into the ignition line with mnor soldering?
yap it does come with a plug n you can minor soldering to connect it.
NEW STOCK!!
ABN 77 934 867 271
I accept:
- Direct Deposit
- Money Order
BRAND NEW TRUST PROFEC B SPEC II + ENGLISH INSTRUCTION* = $479 + FREE DELIVERY (AVAILABLE IN SILVER AND BLACK)
BRAND NEW TRUST FULL AUTO TIMER + ENGLISH INSTRUCTION* = $129 + FREE DELIVERY
TRUST AUTO TIMER
Speed warning mode
GALLERY
GREDDY AUTO TIMER
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
