I'm around but I was about to give up on this forum. I've never seen one so quiet.
I've been doing a few practice days in my GTR at Baskerville and it desperately needs an oil cooler. Beats me why they don't have one standard.
I'll be installing a new ecu shortly and a few other simple things. I'm currently having a lot of difficulty finding wheels to put on it. Any suggestions for decent wheels for a white R33 GTR? Pic's of similar cars with nice wheels would be much appreciated.
Tim.
https://www.sau.com.au/forums/topic/8205-this-is-tasmania/#findComment-121045
Yeah man for sure....
But i think it will have to be designated the pimp daddy cruise...
I have recently acquired a soarer. Auto (yeah, yeah i know) but it has GReddy Profec boost controller, 18s, awesome drift exhaust, dumped as suspension dark tint mmmmm...
what has been happening down your way, buddy?
https://www.sau.com.au/forums/topic/8205-this-is-tasmania/#findComment-123440
Hey man,
When would suit you for the pimp daddy cruise? Please, everyone in tassie pipe up so we can get a few together.
Last cruise was a success, just ask all who participated!!!
So lets get behind this cruise and have a little fun!!
https://www.sau.com.au/forums/topic/8205-this-is-tasmania/#findComment-123935
hey Young GT-R.. (steve here) Dave didn't realise he was postin unda my name. Anyway.. As you can see the Drift/rally practise car has turned out to be an R30 skyline .. hehe.. Shame it's auto. Still drifts a bit. Doesn't go too bad actually.. 2.4 litre EFI straight six. All in fun lol... Later anyway...
Steve
https://www.sau.com.au/forums/topic/8205-this-is-tasmania/#findComment-124356
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
