Hay guys my car is on its way and iam budgeting for some things id like to put on there?
from what i have been told i have a stock ecu?
the car a large fmic i think its hks, exhuast cold air intake, suspension sway bars and who knows what else lol. i think it was used for drifiting also its a 97 180sx =)
it also has inside a profec b boost controler and some one said it might have the old style apexi afc but not to sure =)
now if it does have a stock ecu?
should i replace the old boost controler and put in an avcr and rsm? is it worth getting rid of the profec b or is it preety good?
or leave that crap out and put in a power fc with hand controler?
reason iam asking is with the mods the car has how well can the stock ecu perform with these mods???
e.g to performace pinging air fuel etc.
and how much can the power fc help me with the kind of mods i have?
Thanks for all the help guys..
ohh here is the link to the mods on my car from the last post. =)
http://www.skylinesaustralia.com/forums/sh...=&threadid=8021
Cheers
Wait until the car is here.
The reason I say that is that sometimes gear can be pinched from your car while on the docks.
Sad but true.
Don't waste your money on s RSM, I'm sure you've got a speedo and tacho on the car that works.
The Profec b is a good unit, hold onto that.
You might find that the ECU has been remapped, so wait till it get's here.
When the car get's here go right over the whole car and find out what it has, and if need it be run it up on a dyno and check A/F ratios, fuel pump preasure blah blah blah, decide from that what you want and need.
Once you get the power bug you'll want more though :D
When you get the car, dyno it and get a read out of a/f ratios. If it's too rich, SAFC.
Ask yourself, why do you want the RSM? Rice factor, or for the data it can give you, and do you know what it means?
If you intend on modifying the car more in future, get the PowerFC or something similar, and don't waste money on something you'll end up replacing, ie. SAFC.
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
