Good straight through mufflers that don't impeed the airflow won't affect performance much at all.
I plan to replace the center resonator with a decent straight through muffler to keep the cabin drone and noise levels down once I fit the larger turbo.
Larger turbo's place less of a restriction on the exhaust, as a result they also make the car louder.
https://www.sau.com.au/forums/topic/85655-muffler-question/#findComment-1550290
Aint that the truth.
I have a TD06 and i can't get over the difference fromt he stock turbo with noise :D
Now i ahve to get a desent exhaust and i'll be right :)
https://www.sau.com.au/forums/topic/85655-muffler-question/#findComment-1551433
