- Rb20det 5speed manual, dry, emptied of all fluid, unsure of working order, recent purchase of front cut and gerabox not required!!
$400 o.n.o
-HKS cast Front mount intercooler, with plumbing... only small, apparently its a stage 1 kit that they make for the rb20det powered r32..
reasonable condtion
$250 o.n.o
-BOV stock r32 gts-t blow off valve, plumback
$70 o.n.o
-R32 gts-t rear wing in maroon/wine red! great condtion
$100
prices are all negotiable....
call me on 0401 664 828 or pm me or email me at [email protected]
cheers
~~Giffo~~
hey, im in carlingford....
size of the cooler is 260x260 cast iron, comes with all neccessary plumbing to bolt up to standard plumbing....
no body mods req'd as far as i know!!
pm sent.
stuff is still for sale....
not holding anything for anyone....
wen i receive the money its yours!!
stuff is negotiable so make an offer!
cheers
~giffo~
yeah mate i will ship, if u organise it aye!!
only pics i have r on my mobile fone!!
cant find the camera!!
all is still for sale!!!
anyone interested!?!?!??!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
