  • Replies 58
Posted Images
as topic says, im after some pics of the 260rs sideskirts, the dayz ones, and some other brands and i dont want nuthin too bulky and over the top :D
cheers
Brad
Updating my gallery at the moment, so there will be a heap of Stagea pics with the Dayz bodykit in there.
Check these out tho:
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1617641
cheers
Brad
Here is something a bit different. These skirts were on my Series 2 when I bought it. Do not aske me what or whose they are. Sorry about front spoiler - being repaired.
Marc2
ps Will try and have better photos of my car and another Series 2 with a DAYZ kit tomorrow.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1623081
Marc2
Your kit is in the hyper rev mag. It says" M's FACTORY" whoever they are.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1623843
Long as less no shifty looking boat crew member took that as well, (dont' think ernie has mentioned it yet ... l'll find out), l'm more than happy to let u use it.
long as less l a wing gets made with this kit!! :P
Edited by NRGIZD
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625605
I cant make moulds as such, and I'll have to take a look at how it goes on, etc. Dont want to f* up my dayz bodykit!
But if the sideskirt set needs to be borrowed as such so moulds can be made, and orders placed to that mould maker, then we can give it a go.
Im in Adelaide, who has mould-making contacts?
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625615
Going to check out a couple of fibregalss mould shops here in Adelaide this Saturday (hopefully places are open on Saturday). Im full time Mon-Fri so Sat is the only day I can look-see. Can get an indication if copies can be made (without screwing up my skirts), how long it'd take, quality, price, etc.
Hands up for numbers? Who wants Dayz REPLICA skirts? If I can go to some shops and say "take my skirts, make a mould up & do Xamount of copies while you are there, and make 'em good, damn good", might be able to sort some pricing out.
Postage.... need to source the right size boxes, and I can have TNT deliver them. But we'll get to that later. Let me know about the intrest, and I'll see if I can get a quote.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625746
I have the contact who does moulding, i know i am in Melbourne, but thats not an issues.
Moulding doesnt damage in any way what is being moulded. Ive seen moulds been taken before from a bonnet/gaurd and the original was not damaged at all
I would be interested in a replica kit, full kit. But i wouldnt want to pay more then 1000 in total, specially coz ill have to freight it, paint it etc etc as well... and looks aint my priority ATM.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625822
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
