  • Replies 58
Posted Images
as topic says, im after some pics of the 260rs sideskirts, the dayz ones, and some other brands and i dont want nuthin too bulky and over the top :D
cheers
Brad
Updating my gallery at the moment, so there will be a heap of Stagea pics with the Dayz bodykit in there.
Check these out tho:
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1617641
cheers
Brad
Here is something a bit different. These skirts were on my Series 2 when I bought it. Do not aske me what or whose they are. Sorry about front spoiler - being repaired.
Marc2
ps Will try and have better photos of my car and another Series 2 with a DAYZ kit tomorrow.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1623081
Marc2
Your kit is in the hyper rev mag. It says" M's FACTORY" whoever they are.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1623843
Long as less no shifty looking boat crew member took that as well, (dont' think ernie has mentioned it yet ... l'll find out), l'm more than happy to let u use it.
long as less l a wing gets made with this kit!! :P
Edited by NRGIZD
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625605
I cant make moulds as such, and I'll have to take a look at how it goes on, etc. Dont want to f* up my dayz bodykit!
But if the sideskirt set needs to be borrowed as such so moulds can be made, and orders placed to that mould maker, then we can give it a go.
Im in Adelaide, who has mould-making contacts?
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625615
Going to check out a couple of fibregalss mould shops here in Adelaide this Saturday (hopefully places are open on Saturday). Im full time Mon-Fri so Sat is the only day I can look-see. Can get an indication if copies can be made (without screwing up my skirts), how long it'd take, quality, price, etc.
Hands up for numbers? Who wants Dayz REPLICA skirts? If I can go to some shops and say "take my skirts, make a mould up & do Xamount of copies while you are there, and make 'em good, damn good", might be able to sort some pricing out.
Postage.... need to source the right size boxes, and I can have TNT deliver them. But we'll get to that later. Let me know about the intrest, and I'll see if I can get a quote.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625746
I have the contact who does moulding, i know i am in Melbourne, but thats not an issues.
Moulding doesnt damage in any way what is being moulded. Ive seen moulds been taken before from a bonnet/gaurd and the original was not damaged at all
I would be interested in a replica kit, full kit. But i wouldnt want to pay more then 1000 in total, specially coz ill have to freight it, paint it etc etc as well... and looks aint my priority ATM.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625822
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
