  • Replies 59
* Needs more work on the (i'm assuming) carbon bonnet ... texture is totally missing.
* Also on the bottom of the car where you've tried to accomidate the large rims.
* The rims and disk and no-where near as crisp as the rest of the body.
* Front bar is a real mess
Other than that ... I like it :P Post up the original pic and we'll all have some fun !!
https://www.sau.com.au/forums/topic/9079-my-latest-creation/#findComment-135401
Who said anything about ricing it up :D the battle is all about image creation, not so much just chaning a colour here, adding some wheels here.
Have you had a look at a few battles ? They're all about keeping the theme going, ususally by using something from the previous entry, and placing it into something different and new. Each time obviously the challenge gets more difficult to try and keep the theme alive. Check them out.
https://www.sau.com.au/forums/topic/9079-my-latest-creation/#findComment-135613
Guest Diabolik1
Ryan or anyone else who can?,
if u have some spare time? could you try and do something groovy to my car?
i tried and failed miserably...
maybe lower it with nice big rims or something?
if it aint too much trouble?
pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee?
Goz
PS. the pic is here:
http://skylines.pnc.com.au/pics/goran/7.jpg
https://www.sau.com.au/forums/topic/9079-my-latest-creation/#findComment-140809
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
