Well i managed 2 lose my licence the other day, so i have a few things i am gonna do to the Skyline...
Here is what my car looks like now:
I have picked out some bodykit pieces:
Front Bar:
Rear Bar:
Side skirts:
Rear wing:
Let me know what you's think..
Cheers....Luke
Edited by NismoRB25
https://www.sau.com.au/forums/topic/92347-my-33/
All good, though I'd say get a boxier rear bar than that one - its a tad smooth, maybe whatever matches the front bar? And don't do the sheep thing and get the GT-R replica spoiler...
One of those lip spoilers, the one that just fits the dip in the bootlid and doesn't come up higher than the quarter panels would look very fat... Also, in my opinion your wheels won't cut it with a fatter bodykit.
https://www.sau.com.au/forums/topic/92347-my-33/#findComment-1665308
Im sorta with Tim on this one.
Not a fan of HUGE wings but what ever floats ya boat.
The wheels will be the only thing to let it down i think.
Other than that i recon it would be sweet.
You keeping it white of thinking of a colour change as well?
Cheers B
https://www.sau.com.au/forums/topic/92347-my-33/#findComment-1665618
yeah wheels will be changed aswell, im lookin at somthing around 18" with smoked chrome finish....
colour will stay white... its a bit plain but looks good...
i have found some rear corner pods insead of the nismo rear bar...
i will decide on the wing last after the rest of the kit is fitted..
Luke. ;)
Edited by NismoRB25
https://www.sau.com.au/forums/topic/92347-my-33/#findComment-1667650
Luke. :D
Well look forward to seeing it when its done :(
https://www.sau.com.au/forums/topic/92347-my-33/#findComment-1668501
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
