Hope your all sitting down.
Weather deflector kits are around $340.00 delivered.
Stock is ex japan.
Cheers,
Ken
Ken will you be able to get these when ever as i do want them and I will just have to wait a while to get them as the house building budget is starting to blow out big time now.
cheers ICE
My drivers side one is cracked pretty badly, had one of my mates lean up against it, and dint realise it was plastic, yeah yeah dont even get me started on it, but yeah I wouldnt mind a new set as mine are a but faded and the plastic looks like it is deteriorated to the point where they need replacing, but at that price I'd rather just do without them :P
Oh and I heard a rumour that without them the windows leak in the rain.................?
I've got them, but they're both cracked, and i almost lost the drivers side on the Hume.
a quick squirt of silicon gel fixed them up, looks a bit funky but they're not broken and banging anymore.
for $340 i'll pass, mine do alright for now
Can get for you whenever. Do you have mob number?
CBUS is why your house is sooooo expensive.
Had to drop the CBUS as i had to buy a bigger patch of dirt as the house wouldn't fit on the first one. Its the purpose built home theatre that took a bit $$$ and now just found out I have to spend $15,000 on a retaining wall, not happy. I will PM mob number.
Cheers ICE
Mine are in perfect shape, no cracks, not loose or anything. I may reseal them on with some sikaflex though just to be safe as you guys all seem to loose/nearly loose them on the freeway's
x2 ... mine are in mint condition.
Better look into sticking them on with something else as well, as l drive on the freeway quiet a bit.
Stock is ex japan.
Cheers,
Ken
Hi Ken, does the price drop if we buy multiple kits? Packing multiples all together should be a lot easier.
:) cheers :)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
