Im definatelly in! The last cruise i went on was sweet, but there was no bbq. food = :angry: i didnt have the radio last time. i'l be gettin one for this time though. we need it for ppl like Dave, he has a special talent that allows him to somehow stray miles away from huge conga-lines.hehe.
P.S. first name Adam, R32 GTS-4, dark blue.
Edited by GTS4dood
  • Replies 190
i only just got my licence back 2 days ago so im overly keen for a cruise. I gave myself a "welcome back to the roads" present of a full 3" turbo back exhaust system, and then on my one week anniversary im fitting up a blitz intercooler system. so she'll be ready for the cruise with some nice mods. ahhh.....i give the best presents! :O
Got a couple of local guys up here who are coming out for the day...2 x R33 GTS-t's Matt(dark grey/silver) and Josh(burgundy) (i think its josh)
Edited by DiRTgarage
More the merrier!
Glad you can make it Adam....and i aggree about the UHF radio's...lol
They also make the cruise more interesting, cause you can chit chat along the way. B)
Crew's growing in size rapidly now!!
Looks like it will be a top day.
Paul and Stace, how many $$ would you like each person bring for the BBQ?
I will confirm we have the "floating carpark" for parking and photo's...but ppl we must be on our best behaviour. It is a 40m x 40m concrete platform built out over the water next to Soldiers point Marina. It is used as Geoff D'albora's helicopter pad ($$$). We should be able to fit all the cars in "formation" on there and should look unreal. Trying to obtain use of Soldiers Point Yacht Club which overlooks this area for photo's BBQ and drinks, but should be able to pull a few strings to get it. Will need definate numbers before i can work out a price for catering but if everybody budgets between $5 and $10 each it should make for a great day.
I just checked out the list and it looks like out of everyone theres only 3 R32's! thats not cricket. And the 2 besides mine are GTR's. Last time there were a heap of 32's. :blink: also how many ppl have UHF radios?
That sounds awesome Paul!
Good work mate. This is gunna be tops.
I have a UHF radio. And anyone that doesn't, get on down to your local Dick Smiths this week. The Uniden radios I got come as a pair and are on special for $50. So split the cost between you and a friend, and it'll be all good.
Yeah, def. get your hands on that UHF deal at Dick Smiths Adam. Get Heffo to go in with you so its only $25 a piece!!
Price for the BBQ sounds more than reasonable Paul & Stace, thanks for pulling some strings so we have some nice locations up at the point too!!
mmmm bbq :D
List has been updated...
hopefully i will see you there on saturday paul.
Suggesting an earlier start so we can get back to newcastle in time to meet up with the sydney crew. we could do the photo shoot before the bbq. perhaps a 9.30 leave from speers point?
So that means:
Meet at 9:00am at Spears Point Carpark
Leave by 9:30am to commence to cruise from point to point!
Everyone able to make that? Was just talking to Chris about it and we think thats the only way we will have time to fit everything into the day..!
I might not be able to make it fellas... my turbo has just buggered itself.. im in the process of getting a standard turbo on there asap so hopefully i can meet the deadline and go on this cruise! Wish me luck! haha
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
