HUUUUUUUUUUGGGGGEEEEEEEE LAG! thats one of the main side effects for whacking that on an RB20.....and ul loose a fair whack of torque. I was gonna put one on mine, but now im looking at other ideas. Power however will be great u can get a bit out of em, over 280rwkw. or around that mark. Ul probly need ecu, injectors, Z32 afm and a decent clutch sum sort of twin plate.
https://www.sau.com.au/forums/topic/95602-trust-td06-20g/#findComment-1730286
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
