I have started work on my RB30 block which will end life with and R26 head and singel turbo.. The one I am using came without the provisions for the oil feed and return already in the block. The water feed is however there. The oil feed hole is tapped into the block with a hole about 4-5mm diameter going down inside the block, after about 3.25 inches this appears blanked off. I have another block with the feed hole already in and this appears about 5.5 inchs deep before it stops and presumably enters the other side of the block by the oil filter. Can someone tell me how deep I need to drill to open the hole through to create the oil feed and what size should it be. Also what size should the threads be tapped for the oil feed and return. I was considering the option of running a feed from the oil pressure switch. What have other people done with their blocks with out the feeds already in?
Thank you
Lee
Dont ya just love RB blocks!
Yes, not all the blocks have the oil passages that go through! I have seen this before in my wifes old VL. It had me stumped for awhile.. So I just 'T'ed into the oil pressure switch on the other side of the block and got oil from there and screwed the oil pressure switch back in. Boom shuck a luck, Turbo had oil and no idiot lights glowing in the dash.
As for drilling out the hole to nowhere.. I nearly did that, I looked at another block that had the oil gallery that went through and I was just going to copy it. My machinest said that I could do it, just drill through until I hit the oil gallery that it was supposed to join up to. But be very careful not to deviate or.. acutually I cant remember why!
Does your block have the oil return just above the sump line like all the other RB's, or does it have a blank 'pad' that looks like it was supposed to be drilled and tapped? If that is the case.. save yourself the pain, get the machinest to do that as well! You can do it if you have the tools, but if you dont, it will probably cost you more to buy the tools and do the job yourself!
Thanks for the reply psi,
I think rather than risk knackering the entire block for a tiny hole I will take a feed from the oil pressure switch! My block is blank on the return hole as well.. I am toying with putting the drain into the sump anyhow.. But I will think about that a bit more yet..
Only other thing I need to check out is the arrangement for the belt tensioners. But that's another thread I think!?
Cheers
Lee
there are already threads about the belt tension positions.. have you read the guide?
As for your block, it sounds like you have what is called a series 1 RB30, they are the blocks without all the holes that you really want! No fear, you can either machine them into the block, or by-pass them and get oil from the oil switch and return it into the sump. I did the later in a VL when I converted it a few years back. The best option is to put them in where they really belong.
If you go the later way, make sure you put the oil return as far above the oil level in the sump as you can. the fitting will need to be heat proof and oil proof (like a welded in fitting). Oil leaking there will really get to you!
As for water lines, get them from the plenum side of the engine somewhere and run them to the turbo. Be extra carful to stay away from hot bits and things that can chafe..
happy boosting
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
