Item: 1991 gtir
Website:
Item Condition: excellent
Reason for Selling: buying a house
Price and Payment Conditions: $16500
Extra Info: 18" ozzy racing wheels,frontmount intercooler,custom stainless plumbing,greddy profec b electronic boost controller,hks ssq blowoff valve,hks boost guage,550cc injectors,after market fuel pump,illuminous dial guage cluster including din guages,shift light,apexi turbo timer,sports wheel,cusco front and rear strut braces,heavyduty clutch,new front cv shafts,reconditioned gearbox,immobilizer,clear side indicators,3" mandrel bent exhaust, rwc 6 months rego,clean neat car regretfull sale but i gotta buy a house...please note number plates not included in sale!!!!! 94000klm's
Pictures:
Contact Details: ph 0422884729 Jade.. !!!! price drop $16000!!!!!
BARGAIN...
Edited by skid
https://www.sau.com.au/forums/topic/100555-1991-gtir-fmicebcquick-tidy-car/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
