MAJOR FEATURES
Tuner RDS EON
ABC (Automatic Bandwidth Control)
Mechanism
1 x Compact Disc
CD-R/CD-RW Playback capability
Max. Output Power (1kHz, 4 ohm) 4x52W
Dynamic Soundstage Organizer DSOII
EQ-7 (7 Band Equalizer)
Pre-Amp Output
Technical Data
Tuner / ABC (Automatic Bandwidth Control)
Station Presets: FM / MW / LW
BTM (Best Tuning Memory)
RDS EON
Mechanism: Compact Disc
CD: CD-R / CD-RW Playback capability
CD: CD Text
Title Scroll: CD Text
Frequency Response 10 - 20000 Hz
Signal to Noise Ratio 90 dB
Repeat / Shuffle
Changer Control: CD / MD
CD Custom File Control: Disc Memo / Bank
Display of: ID3 Tag (Track-, Artist-, Album Name)
Display of: CD Text
List Function: CD / MD
Title Scroll: CD Text / MD
Repeat / Shuffle
Output Power (DIN 45324, 4 ohm) 4x 27 W
Max. Output Power (1kHz, 4 ohm) 4x 52 W
Dynamic Soundstage Organizer: DSO II
Separate Bass, Treble Control
Loudness
Pre-amp Output: Front / Rear
Sub Output / Switchable Low Pass Filter
Sub Volume Control
AUX Input
Display: Dot Matrix
Display: Multi Colour
Display: Contrast Adjustment
Display: Display Dimmer
Key Illumination: Amber, Green switchable red
Safety Commander Interface: 3.5 mm jack / Infrared
Sensor for IR Commander
Removable Front Panel
Integrated Clock: 24 h
Telephone Attenuator
ISO Connector: Supplied Adaptor
Supplied Adaptor Cable (radio / car harness) 16pin / ISO Installation Angle 0-60o
Dimensions (WxHxD in mm) approx. 178x50x182
Remote Control:
Safety Commander RM-X6S
IR Card Commander RM-X113
$250.00
Contact: 0424908241
https://www.sau.com.au/forums/topic/101432-sony-cdx-ca900-cdmp3-player/
