  • Replies 69
Guest Sypher Dyas
I was at Chappel St a few weeks ago for the first time. It was awesome, Skylines everywhere!!! I felt rather sorry for myself in my R31. One day I will upgrade....I hope. It was quite funny to see all the VL boys in the Safeway carpark, they were probably hiding from the Skylines. Too bad it takes me 90 minutes to get to Chappel St
https://www.sau.com.au/forums/topic/10247-sky-grl/page/2/#findComment-161830
Originally posted by inark
anyone know who this is?
i think that was how it was spelt...
its a white GTS with an exhaust, skirts, aftermarket rims... seen her around a few times but i dont know of anyone on here of the female persuasion that drives an R32 (apart from Shan)
lol inark, I KNOW WHERE SHE WORKS! heheEH. the plate is SKYGAL
:D;)
https://www.sau.com.au/forums/topic/10247-sky-grl/page/2/#findComment-161869
Originally posted by MzDfectd
ANYONE KNOW THE POOF WHO OWNS THE WHITE R33 PLATES INASNT
FWOARR WAT A WANKER!!
SUCH A MUZZA HERO WANNABE
:D
oh really??
what about that shitbox/ricebox/inbred holden/opel calibra driving around on chrome rims and sum real short chick driving with the plates AMBZ??
Oh and who dates muzzez she picks up from chapel street??
https://www.sau.com.au/forums/topic/10247-sky-grl/page/2/#findComment-161898
;):D
lol yes amongst all the spam this has been established.
:D
once again ur telstra skills of observation are put to the test.... and once again... failed ;)
jk. lol
https://www.sau.com.au/forums/topic/10247-sky-grl/page/2/#findComment-161924
That girl...is very bitchy...sorry to say......my guy friends know her
and ambz u are right...she is very UP HERSELF
thinks shes the best....and seem to be the only girl who drive such a good car....
betta watch out...go for a cruize?how about u guys ask her bf first?
i think he bought the car for her and modify it for her...that what i heard from frends in boxhill and glenny....
well...up to u guys now^^go try ask her to join^^
https://www.sau.com.au/forums/topic/10247-sky-grl/page/2/#findComment-161940
are u talking about or to ambz here?? u sure skygal and ambz aint the same person??? :lol:
https://www.sau.com.au/forums/topic/10247-sky-grl/page/2/#findComment-161988
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
