Hey all. I've got an rb20det in my silvia.
Has:
high mount manifold
rb25 turbo(Modified to use external gate)
external gate (14 psi spring)
Front mount
3"exhaust
walbro fuel pump
sard fuel pressure reg.
(Car doesn't drive atm... just has these things fitted)
I have an safc 2 sitting in the garage, will the safc be able to cope with this setup? (Will it be able to handle a minimum of 14 psi due to external gate? (Not planning to run more then 14psi on rb25 turbo :)))
If required, does the safc cope with changing injectors/afm???
Ta.
Chris.
https://www.sau.com.au/forums/topic/103274-apexi-safc-up-to-the-task/
The SAFC is ment as a piggy back system to trick the ecu and since your using an RB20 ecu you don't need to trick it. It's ment to see boost and to run 270cc injector's which are in your motor.
Now those injector's won't handle 14psi for very long as you are just (if not for sure) maxing out the duty cycle and an SAFC won't be able to fix that problem. A boost controller, along with the rest of your set up, will allow you to run 10-12psi ish and be fine. You can wire it in if you want and yes you can add some fuel but only a dyno will be able to determine the correction needed. So if you do install it make sure to leave your LOW & HI throttle maps at 0% +/- as that will have the injector's work normally.
If you plan on using larger injector's then YES you'll need some sort of fuel management at that point along with either a dyno tune or a tune from someone with a wideband to make sure your a/f's are good. The SAFC will be fine for injector sizes up to 550cc. Some people have run those with no problems while others have said they can't get the right settings and needed more of a stand alone system. I guess it's all a matter of getting lucky.
Well I hope that helped you out and good luck with your project. ;)
Cheers B)
He can't run less than 14psi because that is what spring is in the wastegate, doesn't matter what you set the boost controller to.
If it was me I would go for a PowerFC with some larger injectors, much safer than running everything maxed out.
The problem with the SAFC is it doesn't allow any tuning of ignition, infact because you're messing with the AFM voltage, it can result in too much ignition advance, meaning it's always a comprimise with tuning the afr's.
Also I'm pretty sure the ceramic exhaust wheel on the turbo would be haveing a very hard time if your running at 14psi all the time. Maybe you should consider a turbo rebuild as well.
Dont mind if everything is running maxed - as long as it can cope with it. (Dont' want to put it on the dyno, find out something can't handle, buy that thing, put it on the dyno, find another thing etc etc)
Would rather just have it all there and ready. Don't want to run more the 14pis. (or less :D)
I s'pose that it's always going to be a touchy subject as most people get different results etc - so i might just have to bite the bullet and see if the safc can cope with what i want on std injectors, if not - new injectors for me, and an safc will be up for sale with all of 15 minutes dyno use haha...
Thanks.
Chris.
should easily be able to handly it i ran an rb25 turbo off an r34 fmic gtr fuel pump malpassi rising rate fuel regulator and 3" turbo back on stock comp at 14psi everyday and occasionaly on 16psi and never had an issue so at least with an safc it will be a bit better
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
