Wtb: R33 Rb25 Det Box.. $$$$$$$$$$$$$$
Hey there,
Hey there,
IF ya have any of these boxes let me know and give me a reasonable price including postage and ill send cash your way straigt away :) SIMPLE!
- R33 TURBO 5 speed box
- R32 Turbo GTST box...
P.S i know all these boxes and the difference so dont fool me :)
Thanks Brenton..
RING ME on 04 10 756 872! and ill chuck some money your way..
P.S have to have warranty!
CALL WHENEVER!
https://www.sau.com.au/forums/topic/103922-wtb-r33-rb25-det-box/
