Ok so at the moment i only have the GTR fuel pump and its making a few unhealthy noises :lol:
Car in question is a R32 GTST with a TD 06 and a few other mods.
So its got me thinking to what im going to do.
Im toying with the idea with a swirl pot and different fuel cell but then its just a road car so dont really need to go that far.
Do i just buy:
new pump like a 040
change to an external pump set up with a 044
fuel pressure regulator/rising rate regulator
new fuel rail.
Any comments or ideas to point me in the right direction are much appreciated.
Cheers B
https://www.sau.com.au/forums/topic/104194-upgrading-fuel-system/
just a intank bosch will suffice for a road car
so just go the 040 you recon.
I get out to the track but not as much as i like these days cause of work.
Im running about 1.3bar at the moment and waiting to do a few other mods and get Dr Drift to do the tune to see what power we can get out of it.
But want to make sure that the fuel system will manage and also do away with the extra injector set up.
Cheers B
yeah i reckon, if you havent had surge problems in the past, bosch intank (mounted correctly)
Should be perfect
no surge problems that have been fuel related as far as i know.
Would you suggest on replacing the lines as well or just give them a good flush?
Cheers for the help R31Nismoid.
I'll have a look in the sponsors section to see if i can find one :D
Cheers B
Can anyone shed some light on how to effectively mount a Bosch 040 into a R34GTT?
I've got one in there at the moment, but after going for a test run last night there was some surging. Problem is that the stock pump uses a "sock" which WILL NOT go onto the 040 due to size differences.
Sorry to rob the thread but yes, any help is good.
Oh forgot to add that the surge effect was experienced going at 80km/hr up hill through a sweeping left turn. Fuel tank was at the half way mark if that is any indication.
If anyone can shed some light, or even direct me to somewhere that shows exactly how to fit the fuel suction thing (fabricated I assume) I'll be most appreciative :D
i used stock fuel lines on my 25/270rwkw :D
should be arite i'd imagine  :P
SHould be fine then with a full flush
HA HA HA
that was my next question, is it a good idea to run the fuel sock and how do you mount it "correctly"
i think it quietens them down more than anything else.
My crap - useless - piece of junk walbro came with its own one.
not required though.
surge sometimes is a few things stan
could be a pump in not-so-good
pump not mounted not-so-good
I cant say i ever had surge (HR31 tank) unless i had 1/3 or less :D
1/2 a tank and surge is more likely one of the "not so goods" :P
Cool
well i'll throw it on for good measure.
They are pretty straight forward to mount i take it, do i have to take the tank out of the R32 or is there allocation made with a panel to get access???
Cheers B
I've got a similar fuel problem which was happening 2 weeks a go at Eastern Creek and I hope you guys could help with as I'm not sure if it surging or fuel rate problem.
When doing a sharp right hand turn (turn 9) with a third of a tank left coming out of the corner I would get no power and the car would misfiring.
When I filled the tank up again it went away. I have and 270rwkw r33 gtst with a bosch 040 fuel pump and 555cc injectors.
Do I need a surge tank or fuel regulator? Any help much appreciated.
So what's the trick? Should I extend the intake hose that we've fabricated? Or simply lower the pump further into the tank?
Option 1 will be easier...
I would've thought that less surging would occur if the pump was lower into the tank???
This happens all the time, usually because the pump is mounted too high and has no extension of the pick up point towards the bottom of the tank. The best way is to duplicate the standard pump location and pick up point EXACTLY. Nissan obviously spent a lot of time researching the best pick up location for the fuel tank shape, best to copy what they have done.
My local AutoOne, AutoPro, AutoBarn, Repco, SupaCheap etc has a pile of fuel fittings, hoses and adaptors. I just take the 2 pumps in there and mix and match bits until I get what I want.
:P cheers :)
Thanks SK...
Well my mate is playing around with it today; I'll see what he comes up with, apparently got some fancy hose from Enzed and says it'll do the job :P
If not, I guess we're going to mix n' match!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
