I'm wondering if anyone is interested in meeting for an RC drift day (or few hours) sometime?
CONFIRMED FOR SUNDAY 19th , 12PM at Curl Curl Netball Courts:
Me - HPI Sprint
Paul - Electric buggy
Steve-o - Tamiya TL-01
Mr 32 - Nitro buggy
Kaza - Nitro w/Skyline shell
Satanic - Prolly filming for us!
Mitch_Rona -
qwrx - Electric w/WRX shell
gnif - spectating
Edited by RANDY
https://www.sau.com.au/forums/topic/104492-eoi-rc-drift-meet/
  • Replies 158
Posted Images
Electric, Nitro, newbie, old car... doesn't matter! I just want to go out and have fun with others, and prolly video tape a bunch of it. (got wireless cam)
Hopefully we can get enough people together to make some kind of make-shift track! =-]
Please also post the dates that you are free.
If we did it on a wednesday night (i work every other night except friday and the rare thursday) we could find a well lit shopping car park
i.e. coles
Problem with that is the shops usually close around 10-1030pm which is quite late to be starting
Yuk man! That track is HORRIBLE! If you want a well-maintained offroad track, with BIG jumps, and a table-top, North Ryde is the place to go!
I've competed with the North Shore RC club a few times in the 1/10th modified truck rounds (and won a few times!) with my HPI RS4 MT... pictured below with road-tyres on it.
First post updated...
I've emailed Castle Hill raceway to see if it's open to the public on non race-days. Looks to be a nice track, smooth, and has ripple-strips.
I'd be happy to get a bunch of people up there for some fun... the netball courts would require rope or PVC halves to make a track.
christ... there's an indoor one there??
I've never seen it! I've done the offroad one a few times, and i've been to heaps of markets at the grounds there... but i've never seen a track! Do you remember if it was open to public all the time, or if you had to book or pay when you turn up or anything?
This could be perfect for a drift day!
hmm, could be interested if organising an on road night depending on location and if i have to work, me and a mate have nitro's :), just gotta fix my front end, rc with no cover vs. dyno = :P
Edited by oRiCLe
AaronMine's electric... but depending on where we go, nitro shouldn't be a problem!
All you really need is an onroad 4wd car, with tweakable suspension and camber (re-positioning the shocks) and some PVC. Wrap tape around a bare rim until the PVC goes on quite tight, and there you have it!
For the 4wd aspect, belt or shaft shouldn't matter. I'll post some vids up of my car. I'm sorting out an R34GTR shell at the moment.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
