Hi all , firstly would like the ID Tag no's from one of these if possible .
I have found different figures for the turbines in these turbos , HKS USA site shows ~ 58 x 54mm which sounds like a mildly cropped GT30 turbine . Some pics I found from a string at Performance Forums shows the turbine at 63.99 x 58.8 mm which is basically GT32 turbine dimensions in 84 Trim .
The compressor is shown as 82.46 x 60.64 so 54 Trim .
If anyone has one of these turbos would it be possible to measure the wheels even if from the outside of the housings to confirm the sizes .
The difficult thing to know is whether HKS got Garrett to crop a 68mm GT35 turbine or used a GT32 turbine with the GT30 or 35 sized shaft and bearing pack .
Either way you could say the HKS GT3240 is a slightly reduced optomised GT3540R ie with slightly smaller trim compressor and turbine mid way between GT30 and GT35 to pick up the response . I think its power rated at ~ 570 ps where the GT3540R is around 700 Hp , 700ps ?
If all my assumptions are correct , with a suitably sized (a/r) and T3 flanged turbine housing this would suit many that are asking for more than a GT30R can give with less lag than a GT3540R would have . Typically HKS want to charge a lot more for something thats a little less for their "Power and Response" monica ...
Cheers A .
https://www.sau.com.au/forums/topic/104680-hks-gt3240-id-and-details/
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
