i've just had a monster tacho with shift light installed in my 33 and the revs on the monster are about 100-200 below that of the standard tacho...
is this because the standard one is wrong, the monster is wrong or because one of the wires is too long or somethin, because i thought that the exact same signal would b sent from both tachos so i dont know why/how they can b different
and i did snip the brown wire, or which ever one it says to for a 6 cyclinder...
any help????
https://www.sau.com.au/forums/topic/10569-monster-tacho/
Originally posted by R31 Skyline Chick
Does it have any sort of calibration adjustment?
Did you try reading the instruction manual?
(oh wait, what am I saying.. guys don't read instructions:p )
I am not sure if it has some calibration adjustment... I have no instruction manual casue it came with the car...
https://www.sau.com.au/forums/topic/10569-monster-tacho/#findComment-170400
interesting, about 8 replies and no one has a useful fkn thing to say :lol:
i got the tacho cos i wanted it, u got a problem with that..deal with it! i read the manual, calibration involves cuttin 1 wire to suit a 6 cylinder, and its done right cos it would b way off if done wrong, not 100-200rpm....any more brilliant comments/questions?
https://www.sau.com.au/forums/topic/10569-monster-tacho/#findComment-170639
hehehehe jet!
my s-afc is a few rpm off from my tach also, the safc gets the signal from the ecu and is digital, so i am assuming its more accurate than the tach
https://www.sau.com.au/forums/topic/10569-monster-tacho/#findComment-170771
hahahahaha, i've only ever seen a few serious replies from you fatz, altho you could have done more in maintenance, or performance, but i don't look there much.
not having a go at ya, just it's funny to read most of them! :D
https://www.sau.com.au/forums/topic/10569-monster-tacho/#findComment-170992
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
