Motorola V3 (silver) for sale
$250 ono
im also in Sydney
Mob: 0423 458 874
you can view all features on this site :
http://www.mobile-review.com/phonemodels/m...ola-v3-en.shtml
Edited by happygabby
https://www.sau.com.au/forums/topic/105805-motorola-v3/
Hello, what V3 model is it? as the series 1 came out first and dosent have some features such as video record, etc
the series 2 came out soon after along with the black version which has upgraded features and software.
Also, how negotiable are you on the price?
Location?
https://www.sau.com.au/forums/topic/105805-motorola-v3/#findComment-1950384
