Just an update from the closed thread which was not updated
Here is a link for all you stagea folks
http://www.skylinesaustralia.com/forums/in...1&t=105610&st=0
I probably wont run this group buy again, so get in while its hot :P
Even if you dont have the car yet, but its due to arrive, its a pretty good price/opportunity, so.... i suggest it :D
Cheers,
Alex
Just trying to get some more people on board before it closes, this is really a good cheap/effective upgrade.
My old tranny cooler, after some normal driving i couldnt touch, it would burn my hand. This new one, I can touch it and its hot to the touch, but doesnt burn. THATS JUST NORMAL DRIVING. dont want to think what it gets like when i give it some stick around some corners!
So yeh, upgrade is well worth it...
  • 4 weeks later...
hehe :) well i'm still interested but i still haven't got the stag and it could be a while yet before i do...
Should have mine by then and will be interested thanks Alex!
Cheers
Luke
just a note for those on a shoestring budget i have been using a cooler from an ef falcon for the last 12 months its virtually identical to the one in the link it cost me 30 bucks from the wreckers
  • 4 weeks later...
  • 4 weeks later...
I said in the previous GB that Id invest my own cash to secure this group buy, well I did and I am now stuck with 7 tranny coolers under my bed.
Anyone else still interested in buying a transmission cooler?
So far:
humble
bwilkeson
pkblade
skidkid x2
wagon
AMS
Nightcrawler
MR_RS4
gr3ddy
[sTAGEN]
Fastrotor
SWC945 (didnt get it direct through me, but I assisted him in getting the same deal/product)
66yostagea (sent last week)
All happy participants....
Its definatly not something you want to live without in Australia. I hear Stagea gearboxes aint too common... :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
