ok, anyway after some months with my engine out of my gtr, its time to re install..
now, ive searched and searched for the best and most efficient way to do this, with no luck finding anything, i need some assistance
we have looked, and cant decide, wether it will be easier to remove one driveshaft? both drivshafts or none?
we had a trial run, but were pretty sure we cant get the drivers side driveshaft in, and the clutch lined up with the pass driveshaft as they clash when trying to line up the 2 splines.
any advice will be much appreciated and or tips, but please, i want to know definate ways, not just , well i think it will be easier because in my mind it would work that way, i want people to reply who have put the engine back in etc
https://www.sau.com.au/forums/topic/106892-rb26dett-engine-install/
She will go in the same way you took it out !! I usualy take engine + box out as one unit and put them back in the same way .
I dont understand what you on about driveshafts, the pass you undo the 6 bolts an dleave it there . The drivers side you either have to pull out or drop the lower control arm and slide it out so you can lift the donk out . Put it back the same way as you took it out dude as simple as that . I usualy assemble everything on the engine before i put it in .The air cond pump and power steer pump i tie on the car on the pass side and leave them there .
If you still have the box on the car you will have to drop the box mount down so u can do up the top bolts just like you did to undo them . As for the clutch you have to make sure you line it up with either a tool or an old input shaft ! If its not lined up well you wont be able to bolt it on .
hrmm, thats what i suspected, but it just doesnt seem to be working ...
we didnt need to pull box out, so we didnt.
this is on r32 not sure if it would make much diff between 33,34...
we will give it another go tomorow nite, the clutch was lined up using tools. however, not sure if spline is 100% correct but nothing that cant be wriggled into it
You are going to have to undo the box so you can twist it around , thats why i take out engine box together , some people just drop the box under the car, i find it easier to take out engine box together , each to their own . 32 , 33 +34 all the same, i've done them all .
ahh ok kool. well the problem with just leaving box out is that were doing this on a driveway due to lack of work space in garage.so we have to be able to push car in/out as need be.
we will prolly be doing it this arvo/night provided the rain stays away. but thanks for your assistance
Its not easy on the floor, if you had a hoist would be much easier . You may have to jack the car up on stands as high as you can unbolt the box and sit it on a jack ( you may have to chain it on to the jack ) .Drop the donk in place and do up the 14 mm nuts on the engine mounts then try to bring the box up to the engine, it maybe better to put something under the front of the engine sump so the engine leans back as much as possible that should make life easier for you .
Now you can see why i take out engine + box as one unit much easier but you have to lift the combo a lot higher to get it in .
If you need any advice while you are doing it pm and i'll give you my number, i may be able to help if you get stuck .
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
