Yeah if you post within 3 mins of another post, then it joins them up, I guess to prevent post whores from filling threads up...?
Still AwEsOmE pictures eh!! Thanks! I see QLD plate there :P
Really nice scenic place to take pictures too! Funny all the black marks on the road, gives it that "beauty and the beast" feeling :)
https://www.sau.com.au/forums/topic/107191-act-stagea-meet/#findComment-1979320
very nice cars guys, but i still think terminals is the best lookin, maybe its the colour, or the fact im not a fan of the series 2 front grille and spotlight setup.
no offence intended for the series 2 guys either, they still look sweet as and the white is a really nice colour and makes them look sooo clean :(
its good to see the series 1 and series 2 models in the same photos side by side, for comparision sakes :D
cheers
Brad
https://www.sau.com.au/forums/topic/107191-act-stagea-meet/#findComment-1980153
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
