Hey Guys, ns.com have organised for Dr Drift (Sam) to bring his dyno down to Tas and do a group ECU remap and tune.
We currently have about 10-11 committed people who have paid their $100 deposit and the date is set at this stage for the weekend of March 25th.
To get Sam to commit to coming down, shutting up his shop for a week and doing us this HUGE favour, we need some more people to join the group.
I believe he can do remaps on most Nissan ECU's and from all reports the result is often better that most aftermarket computers and the total cost is substantially less. Significant gains can even be made on standard engines. Nobody does it better than DR DRIFT!
Taken from ns.com – by Dr Drift
IMPORTANT
I would like to request that ALL vehicles have upgraded fuel pumps (standard are way bad), full tanks of whatever petrol you want the car tuned on, maintained vehicles (serviced, good spark plugs etc). If we can make sure that all cars are ready it will make the whole process quicker and easier for everyone and allow us to tune as many cars as possible.
Remap Prices cover initial ECU modifications, and loading of pre-tuned maps to suit, these will then need 1-1.5 hours of dyno time tuned specifically to your vehicle and fuel. Dyno time as mentioned will be around $180/hr. ECU modification and Base Maps priced as follows:
S13 CA18 - $330
S13 SR20 - $450
S14 SR20 - $660
S15 SR20 - $660
R32 RB20 - $330
R32 RB26 - $330
R33 RB25 - N/A
R34 RB25 - $660
Z32 VG30 - $330
Look at the below link for details!
http://www.nissansilvia.com/forums/index.p...pic=139544&st=0
Thanks for reading!
Todd
https://www.sau.com.au/forums/topic/107866-dr-drift-coming-to-tas/
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
