Hey mate,
FOr the5---((electronic hks gagus out of r34gtt water tep,oil tep,boost pre. with valve controller>$900))
Im offering $500.00 and I'll pick it up???
hey man..
i know its neg prices on them but not for $500 mate,,
am happy to let them go for $750...
cheers.. :mad:
Hey,
not trying to rub it in but the Electronic boost controller, is worth brand new $450.00!!! go to http://www.motorkitz.com......thats what I've been quoted through email.
And including you want to sell thoughs guages with the item, therefore im onlying going to offer max $500.00
think about it.
Regards
Skitzz
Hey,
think about it.
Regards
Skitzz
i wont sell them for that price mate ...
cheers :D
Edited by neo31
neo31
If I remember correctly.....you bought an R34 GTT front cut and put the NEO engine in your 31 right?
Do you still have the half cut ??
Im looking for a radiatory support bar and also maybe some other parts off the front end......
comon guys i want to get ride of these parts..
make me an offer.. :D
the head units are gone..
still got the hks gagues with valve controler thought.
wanna get ride of them guys.. :devil:
hey all.. :sorcerer:
i decide to sell some items i kept them for my project car.
so i can get some cash money to get r34 z tune nismo wheels and sti brembo brakes elc..
those 2 cd players are import from japan and they need adapter for the local radio,
1---silver kenwood CD+MD player [top pic] in excellent condition >> $450 Ono
2---black kenwood CD+MD player[bottom pic]excellent condition>> $400 Ono
3--local pioneer tape player with 12 CD stacker in excllent condition>> $500Ono
4--power Fc with hand controller for r33gts-t turbo in excellent condition>$1000Ono
5---electronic hks gagus out of r34gtt water tep,oil tep,boost pre. with valve controller>$900
6--- volk racing wheels[[4&5 holes]] for r31&32&33&34,,, 17x9+40 and 17x8+40rear.... comes with 90% of trade tyers on front and 50% rear ones..>>$1300Ono
just to let you know guys reasonable offers are well come.. and won't sell separately.
give us call on 0402541159..
cheers ;)
only the gauges and valve controler are still for sale..
any offers ppl :)
